Engine check light.
Hi all,
I have a 1.4 fiesta  2007 on a 57 plate. I had a front end collision which damaged the front end crash plate, radiator and inlet manifold. I've just finished replacing all the parts and found that the orange engine sevice light stays on. I am thinking that this was due to the collision when the engine was still running and the manifold and radiator were damaged. All is now running smoothly but I want to reset the light. I've tried the brake and accelerater pedal and disconnecting the battery but to no avail. Ideas anyone? Or is it a case for the diagnostics machine.
that's a engine management light some thing wrong you need to read the codes
Engine management warning.
Use FORScan to read the Ford specific codes.
Thanks, I believe I've solved the problem but code needs reset.
Thank you, my friend has the machine device to check this.
Good to hear happy days.
On 4/7/2024 at 8:59 PM, unofix said:
FORScan (for use with Windows Laptop) : https://forscan.org/download.html
It's what many Ford owners use including some Ford technicians.
OR
For diagnostic use only:
