Require help with Sony radio
Hello all, I have an issue with the Sony radio in my Ford focus, simple thing I wanna do is remove one of the Bluetooth accounts on the radio, as when you disconnect and forget this device from your phone, the radio will still ping your phone asking you to connect via a code. I haven’t figured out a way to remove the account from Bluetooth in the radio. This is the type of radio I have, or if you could direct me to anywhere else that may be of any help. Any help is and will be appreciated!
I can't remember fully but there is a list of bonded phones in the menu(s) somewhere and you press it and then select debond
Have a play
Have a play
Thank you, this comment pointed me in the right direction, before I was using menu to check, but turns out I had to switch back to the Bluetooth and then check… learning experience I guess. Thank you for the help
Did it work then?
