Beeping constant from glove box
please see video, does anyone know what’s causing this beeping and how do I stop it?
That's a new one to me. Does it do it when the doors are locked? When the engine is not running? How long have you had the car? Does the car have an after market alarm system fitted?
Had the car for years.  Got it valeted today and since I’ve had it back it’s making that noise. I start it up and its normal, then after about 30 second, that beeping constant.
Last ditched attempt before I book it into the garage.  Any ideas out there?
I would love to know the answer, I'm sure you would too.
Sounds like when the key is left in the ignition switch and the drivers door is opened. The Mondeo BCM is very prone to water ingress which causes all sorts of issues. Have you used FORScan to see what DTC's or warnings it is seeing ?
Thanks for replying, not sure what Fordscan is?  No warning lights on dash.  It started after car was valeted so water makes sense.  Think I’ve figured out this morning that it starts when I press the ‘Max’ button to de-mist the windscreen (doesn’t stop when I turn it off, have to cut engine)
FORscan:
On 4/7/2024 at 8:59 PM, unofix said:
FORScan (for use with Windows Laptop) : https://forscan.org/download.html
It's what many Ford owners use including some Ford technicians.
OR
For diagnostic use only:
