Fuse box confusion
My fuse box in my manual is labelled 1 -27 , all in order.......my fuse box in the passenger side is all mixed up numerically and missing some?!
How do I know if Im changing the correct fuse?
Welcome!
Firstly, this post should go in the appropriate model forum (Edge?) or you may suffer some wrath!
Not all fuses are fitted to all models so the manual should be correct - if I understand your issue
Please ask your question again in the correct forum where it's more likely you'll get an expert on that model! 😉
If the fusebox does not look the same in the car as it does in the manual then it is the wrong manual.
You need to find a diagram that matches your fusebox.
