Parking brake malfunction
This is what i got off my forscan but can't reset it.
I had a new caliper put on rear drivers side and that's works great.??
On 9/30/2025 at 9:08 PM, unofix said:
FORScan will clear and reset all Ford specific DTC's with only two exceptions that I'm aware of. (1) it can not reset a failed ABS pump. (2) it can not reset the 'crash' sensor.
Of course if the repair has been done incorrectly (which I suspect may be the case) then no amount of diagnostic equipment will be able to reset a physical problem.
Does the EPB need recalibrated since the rear brake caliper has been changed ?
The way in which this repair has been carried out looks to have upset the operation of the ABS. Personally I would have rejected the repair as it is incomplete. The garage accepted the job and presumably charged for the work. It's now their problem to sort out the issue whatever that is.
I will pass this on to the mechanic he thinks the new caliper might be the problem awaiting a replacement 🤔
