Maf sensor
My focus mk4 lit up a engine warning light . I checked the fault code,  I'm not sure if it's a new maf sensor o need or o2 sensors.  Iv included the fault codes below.  I done a recommended test on the maf sensor by unplugging it while the engine was running to see if the car would stop but it didn't,  so my question is should the engine have stopped?? And is the problem the maf sensor?? The car is sluggish at times and surges other times.
Any ideas??
Sorry would not let me upload pic
Can you copy the codes if can't upload the picture?
Generally an engine should not stop when the MAF is unplugged.
Any ideas??
P1102:21:EC      P600A:00:EC
With those codes it's probably a leak in the air intake pipework.  Or a blockage in the EGR system.  I would not expect any sensor replacement to fix this.
Iv bought a new maf sensor online I'll be changing it Monday to see if it solves the fault codes once I reset them. I will let you know how I get on, thanks for the help. I checked the pipe work it all seems OK, but I might invest in a smoke machine if there not too expensive. Cheers
Iv managed to upload fault codes
Cheers
I'd not rely on your 'Topdon' code read to give all of the DTC's especially the Ford specific ones.
Ok noted cheers
  • 4 weeks later...
Hi
Iv finally found the issue
It's a leaking egr cooler leaking .
How hard is it to replace and does anybody have any vids  on this
Cheers
Mark
3 hours ago, Mark mohan said:
Hi
Cheers
Mark
Which engine is in this car?
1.5 d eco boost
17 minutes ago, Mark mohan said:
1.5 d eco boost
If you mean 1.5 Diesel then it is an EcoBlue not an EcoBoost.
Yes eco blue
Ok, there are 2 different EGR coolers available for this engine.  Is yours behind the engine or in front?
