Focus MkIV Diagnostic options
I've had my car a year and am looking at what diagnostics options I have and it is becoming blatantly apparent that I do not know my FORscan or my IDS from my elbow. What is available and what are the differences in terms of capability/required hardware etc?
I come from a late Saab so what I know is GM based. For those who are familiar with GMs ecosystem I used to use one of these alongside a couple of different bits of software, GDS2 could do all the standard reading/clearing that an ODBII adaptor but with model specific info and test procedures to monitor sensor outputs. It could also initiate various test procedures. For example, at one point the self levelling sensor in my car broke, I got my mechanic to replace it but their standard diagnostics couldn't initialise it (a fairly simple procedure involving having the car unloaded on the ground and a base reading stored). GDS2 did this for me which paid for the VXdiag in one go as I would have needed to pay a GM specialist ~£90 otherwise. Above GDS2, there is GlobalTIS which has dealer level access to security access and can code keys and modules. Both of these could be used under license from GM on a daily/monthly rental basis.
What are the Ford equivalents?
I see FORscan looks to be popular and can run over relatively cheap scanners as well as the Ford version of the VXDiag Nano that I am familiar with.
I see the adaptor I've linked is also compatible with IDS, this looks to be Ford's official software and probably equivalent to the subscription based GM options I mention above.
So where does FDRS fit in?
Secondly, any recommendations for workshop manuals? I see Haynes have this  and there is also repairbooks.co.uk.
The old ELM327 leads are no longer recommended by FORScan. They should still work on pre 2013 vehicles but for newer cars the vLinker cable or OBD Ex are the ones that should be used.
Important note: after many years of continued project development, even those of few ELM327 that have relatively good quality, ceased to meet all of the FORScan requirements. Besides, majority of the adapters that are being sold under ELM327 trademark have quite dubious quality that dropped a lot in the past: in fact, they have nothing common with the famous "ELM327" brand but name. Thus we do not recommend any "ELM327" anymore. If possible, please use adapters recommended above. FORScan will continue to support ELM327 adapters, but some new functionality may be limited or refuse to work on outdated adapters.
FORScan:
On 4/7/2024 at 8:59 PM, unofix said:
FORScan (for use with Windows Laptop) : https://forscan.org/download.html
It's what many Ford owners use including some Ford technicians.
OR
For diagnostic use only:
i've got a laptop so would be looking in that direction. Is there any particular reason why one of the options is £30 and the other is £75? It seems a big difference for a similar product but if there's justification for the more expensive one then I'm not scared of the outlay, especially with Santa round the corner!
Most of us use the vLinker FS cable.
The expensive one is American and was the only recommended one before the cheaper Far Eastern one was developed with FORScan's input. I believe the American one was also developed with FORScan's input before the other one was.
They are both equally good.
