Mk6 (2005) Fiesta 1.6 Auto, engine light on - dash codes
Well I have my MOT later this week so of course now my check engine light has come on.
I've got the codes up that will show on the dash - no idea what they mean mind. Anyone have any idea? Any help would be much appreciated!
gage
LCD
r0117
Er0117
E 02
dtSt69
dt 1F0F
dtc nonE
SP 0
5900C0
tA 0
t9008C
od 0
F 139
F90001
FL 00
FP 08
7 C
030 C9
bt 119
dtE 40
rAFE35
PAtS 1
A0-FF
A1-8A
A2-80
P01-01
P02-40/50 (flashes between the two)
P05-02/22 (flashes between the two)
P08-00
P10-00
P11-04
P12-01
P13-3C
P16-00
P19-01
P20-06
P21-00
P22-C0
P23-F0
Those codes are of zero use. You need to get the Ford Specific DTC's using FORScan.
The usual problem with a Fiesta Mk6 of that age is the instrument cluster which can be repaired/refurbished by @rd457, but you first need to use FORScan and get the DTC's. Use either the Windows laptop version, or one of the mobile phone versions.
On 4/7/2024 at 8:59 PM, unofix said:
FORScan (for use with Windows Laptop) : https://forscan.org/download.html
It's what many Ford owners use including some Ford technicians.
OR
For diagnostic use only:
I've never found cracks or had success repairing Fiesta units.
Thanks for your reply. Then it is even more important for the OP to get the Ford specific DTC's using FORScan.
EML without limp mode or any other issues...my bets are on a lambda sensor.
Thanks for the replies. Got it booked in for service on monday now so will see what it fails on tomorrow and go from there
