MK4 - Changing the tire size?
I'm in the process of buying new tires. I was told to look if there's a similar size to mine, but much cheaper. I want to keep the factory size because a few euros isn't worth it, or so I thought,but upon checking I saw that the difference is almost €200 for a set!
The standard 215/50/R17 tire is €14X while the 225/45/R17 size is €100.
Will the wider tire work? Can it be programed in Forscan? The difference in diameter is around 2%
There's some very good Chinese tyres now, like the cars.
Just make sure you get ones that have high, "A" preferably, "C" MAX wet and economy ratings.
The old story:
I had a brand new 1.0 ST-Line Focus (DG17 UFV) that had Continental Sport Contact from the factory.
It used to understeer in the wet terrible.
When it was due tyres, x4, I fitted "Acceleras" that had "B" rating for wet.
They stuck to the road like glue.
It's all about the ratings, not the cost
