Interrior Fuse Box / Gem Module Part Number Compatibility
Can anyone help me with fuse board compatibility? Mine is 7M5T-14A073-FG but its proving hard to find that identical code.  Its a base spec 2008 1.6 TDCI.  Would 4M5T be compatible? Also I've read the last two digits are trim spec, with mine being a base spec would that mean any of them would work ok?
8 hours ago, Franzpan said:
7M5T-14A073-FG
Only the very last letter "G" can be different. In an ideal world you should use 'G' 'H' 'J' 'K' but should try to avoid using letters below G for example 'F' 'E' 'D' etc.
7M5T-14A073-F?
Here are some on eBay.
https://www.ebay.co.uk/itm/277302899251
https://www.ebay.co.uk/itm/127510464926
I assume you understand that it will have to be programmed with your car's AsBuilt files.
