Air flow sensor
Hi I wonder if anyone can help ?
I inherited a focus 1.6 petrol auto 2005 . Initially had no problems 😁 I thought I'd service it !!!!fine so far I noticed the airflow sensor plug was loose ( so push in ) .
 Now it pulses and stalls unless I unplug the sensor ?! My thoughts was it unplug all that time or have I created a problem?
Welcome!
Unless there's a direct fix that  someone else knows, then I'd suggest reading codes with Forscan.
It may be that a default value is being used and when you plug it back in the sensor is faulty causing the stalling  but that would need to be determined?
