Standing water under carpet in front and rear footwell
I have a leak in the front and rear footwell drivers side causing the carpet to be soaked. The door seal is loose so I think it is causing the issue. Boot and passenger side are both dry. Under carpet is puddles of water. Where can I get this dried and solved?
It's possible that it could be leaking in from the cabin filter too as they go around the bottom so you would need to check that and seal it as necessary if it has. The heater is the only way it's going to dry out when you seal the leak otherwise it'll just continue to be wet every time it rains.
