Engine transmission light
I have a mk 7 fiesta
I keep getting  yellow warning light . Jagged circle with explanation in it ?
turn car of light goes but comes bk I disconnected battery etc it went for 57 miles but now back on it's running normal    no power loss changing gears fine  I do need a new exhaust ? Anyone have any ideas?
Edited by [email protected]
Wrong word
Wecome?
I suspect you'll be asked to re-post this  rather confusing post in the Fiesta thread?
The warning light description isn't clear to me, the transmission mention confuses me more and new exhaust doesn't seem to follow (unless it's diesel/DPF issue needing much more investigation/codes/testing etc?
Of course, I can easily miss the point and, also I wouldn't be posting an email address on an open forum as I believe it can be scraped off and used nefariously!
Posting in General Chat thread.
Stoney871
By Stoney871
12/11/2019
it has been noted that too many Members are posting messages in the General Chat area instead of the correct Forums.
Any messages posted in the General Chat area that are not General Chat will be deleted without warning and offenders may recieve warning points if repeated instances are seen from that Member.
There are plenty of different Club areas that encompass 99% of Ford related posts, please select and use the correct one.
If anyone is not sure of which area to post something then feel free to P/M myself or other Senior Staff for guidance.
The Moderating Staff are having to spend far too much time chasing this problem instead of maintaining the other areas of the forum.
The General Chat forum is ONLY for threads which DO NOT fit any other category. If your thread is anything do to with a specific model, it should go in the relevant model club section
