BCM pinout
I'm trying to find the BCM pinout of a 2019 focus to install a heated steering wheel to my car, I've found all the parts needed but im going to go into it assuming none of the wiring is in place for it. I'm guessing its fed off the BCM so I need the diagrams to see which pins to add in/tap into. Any help appreciated, thank you
Power comes from the sccm. The HVAC sends signal to sccm to turn on power to the steering wheel via the clock spring.
