Audio default
Hi all, is there any way to set the sync 3 radio to play a particular station on start up ?
If you have your stations stored in the memory it will always come back on to the pre-set you were listening to when you switched off.
If you are defaulting to a non tuned AM station at start up then you need to perform a software update on your head unit (ACM) which will fix the problem
