Focus MK3 Cruise Control Retrofit: Limp Mode After 4s(P061B)
Hi everyone,
I’m looking for help with a cruise control retrofit on my Ford Focus MK3 1.6 Ti-VCT (manual transmission).
I retrofitted cruise control using the steering wheel / cruise buttons (swapped the steering wheel, mechanically/electrically plug & play). I enabled cruise control in the BCM, and the cluster shows the cruise control indicator normally.
Symptoms:
  • Cruise control can be switched on and works at first.
  • I can press SET and it holds the speed.
  • But after about 4 seconds the car goes into limp mode.
Diagnostics (FORScan):
The main fault stored in the PCM is:
  • P061B:47-2C – Torque calculation: internal fault
    • Text mentions something like “monitoring/safety µC fault”
    • Status: intermittent
    • Freeze frame shows e.g. (see screenshot): module voltage ~14.5 V, closed loop, speed ~33 km/h, etc.
Important: The fault only happens when I activate cruise control.
If I drive normally and don’t use cruise control, it does not go into limp mode.
Additional info:
  • In FORScan under “Configuration and Programming”, the PCM only shows AS BUILT (no “easy”/plain-text configuration menu) – see screenshot.
  • Adapter: VLinker (should be stable).
I’ll upload the two screenshots (DTC + FORScan options).
Has anyone seen this before or has an idea where to start?
I suspect something related to clutch signal / brake signal / plausibility checks when cruise control is active, but I’m not sure what to check first (e.g. clutch switch present/adjusted correctly? brake switch A/B?).
Thanks a lot! 🙂
Give FORScan forums a try, you may just need a software update
Hi Dave,
thanks for the quick reply.
When you say “software update”, do you mean updating FORScan itself, or updating the car’s PCM software/calibration (e.g. via Ford IDS/FDRS)?
Just want to make sure I understand you correctly.
The car's software, either PCM or IPC I reckon
The original Cruise Control switch also contains the speed limiter.
When activating the Cruise Control the following parameters of the CCC (Central Car Configuration) needs to be changed.
#23 Cruise Control. Change from “Without Cruise Control” to “Cruise Control”.
#224 Adjustable Speed Limiter. Change from “Without ASL” in “With ASL.
Failing to activate the speed limiter results in errors and DTC codes.
