Forscan identity EPS Module but I can´t acess to him
Hi to all.
Ford Focus 1.6 TDCI ->
I backed up my cluster factory settings using Forscan with the intentio of replacing it with a new one. Howevwe, I'm having a problem: Forscan identifies the EPS module as present, but when I try to access to the same, the program crasches. I also can´t read any DTC errors. I have a message to in the cluster reporting problems with this module.
Does anyone have any ideia what might be happenming? Problem with the wiring? Broken part?
Thank you in advance.
Regards.
Luis_I
