Brake problem
I have a ford transit connect, I have a problem with the brakes when I press the brake it tens up and later it lets go, I har checked everything there is no air or water in the system I am left with 2 options the abs module and the cylinder head has anyone had the same problem with that car please help thanks
Welcome but I suggest you repost in the Tourneo/Connect forum as this is the General Chat forum subject to the Wrath of The Mods (Eeek!)
I think our standard suggestion would be to check for fault codes and use live data?
Water in the brakes (fluid) would be a serious issue and the confusion of either ABS module or cylinder head definitely needs more explanation in your new post as I am quite to totally confused with most if not all of it?
