Halogen Headlight Manual Adjusters - MK3 Focus
Hi All,
Wondering if anyone can offer any advice on this. I have recently replaced dipped & high beam bulbs in my headlights. The drivers side one does not appear to be pointing high enough (road directly in front of the car is very illuminated) I am sure they are installed correctly (tab on bulb to the bottom) so figured I'd just upset the adjustment with changing them.
When I have tried adjusting them using the little manual adjusters they are barely moving up or down & aren't moving at all side to side. Is there a way to fix the manual adjusters or if they are knackered are you stuffed? Really struggling to find anything online about them.
Planning on checking install at the weekend but thought I would seek some advice prior to getting stuck in so if there is a fix I can look at doing that also.
Basically the adjusters this mad man (apologies if you are a member) is pointing to in this video which is about all I can find relating specifically to Ford headlights https://www.youtube.com/watch?v=Z7p7DERvjrc
Cheers
