Focus Mk2 Keyless Start issue
Hi again guys,
After doing more testing and checking wiring, I’m now considering replacing the complete start kit to rule out immobilizer/configuration corruption.
The plan would be to swap:
  • PSM
  • BSM (engine bay fuse box)
  • Instrument cluster
  • Ignition barrel
  • Transponder
  • Key
Basically, a full matched set from a donor car.
My concern is the following:
Since my car originally has the Keyless system, there is an additional module involved in managing passive entry/start. I’m not sure how deeply integrated that system is in the immobilizer logic.
If I install a conventional key setup (cluster + ignition barrel + matched key + PSM/BSM), I’m wondering:
  • Will the car start normally if everything is matched from the donor?
  • Or will the Keyless control module still interfere with PATS authorization?
  • Does the BCM need to be reconfigured to remove Keyless from the vehicle configuration?
  • Has anyone done this swap on a Keyless-equipped Mk2 before?
My goal is to simplify the system and eliminate Keyless entirely if possible, but I don’t want to create an even bigger CAN/configuration conflict.
Any experience with this kind of conversion would really help before I commit to swapping everything.
Thanks again 👍
