focus mk 1.6 tdci limp mode po2599
Hello all, I serviced my car 2 weeks ago and since then it's been going into limp mode intermittently. The code on the scanner is po2599. I've checked the actuator and it moves when turned on then back to the normal position when I turn the car off.
Edited by elliott wins
The oil filter is very close the wiring for the actuator sensor, and the vacuum pipe for the actuator, I would recheck those if it only started after an oil change.
