Mark 3 tdci dpf pressure sensor pipes
Hi folks. Has anyone replaced these or know where to get them aftermarket? I can't seem to track them down..
These are quite specific so I doubt you'll find aftermarket ones. There were two different types for Mk3 1.6 TDCI, either single or double pipes. As you used the plural, I assume yours are the double ones.
Not sure how Ford came up with the price for these. 😬 Genuine Ford Focus MK3 Exhaust Air Supply Tube 1744416 | eBay UK
I had no idea they cost so much tbh. Chucked a pair of Mk2 ones in the dustbin when I was having a clearout last year. You could buy some generic silicone hose to cut to length cheaply. Just need to swap any hose clips and clamps, and ideally the heatproof sheathing from your existing pipes. Silicone Vacuum Vac Hose Pipe Tube 3mm 4mm 5mm 6mm 7mm 8mm 9mm 10mm | eBay UK
Thanks for reply. I was assuming that there were 2 as I thought there was one pre dpf and one after, but not checked yet! That does seem steep for some silicone hose and clamps!
