Clutch/gear issues
2017 ford focus 1.0 ecoboost st line, had air getting into the clutch hydrolic system, i had the master cylinder, slave cylinder and a new clutch fitted a few months ago, developed an issue whe sometimes I can feel the gears when changing, not smooth at all, so I had the gearbox changed, still have the same problem, also full gearbox oil changed and pressure blem the clutch, any suggestions out there ? Thanks
If the gearbox is still as notchy, after paying for the gearbox to be changed, then I'd have to suspect it's still the same gearbox
Hi my 2007 Ford Focus ST just went into limp mode and i have tried everything even key coding cluster dry joints and bought a new computer box and cloned it but the vehicle does not want to crank at all. Please help
Make a new post in Focus Forum please.
That has nothing to do with gearbox issues
Its a different gearbox that was fitted, i bought it myself, i feel it may still have something to do with the clutch as it doesn't do it in everyday gear.
