No crank on 2007 Ford Focus ST
Hi my 2007 Ford focus st mk2 just went into limp mode tried everything from key coding to buying a new computer box and having it cloned but the vehicle still does not want to start please help me.
Solved by DaveT70
Why would you code new keys just because you went into limp mode? And what computer box??
And is it actually in limp mode or just not starting?
Limp mode normally means it still starts but reduced performance.
Get set up on FORScan with a decent lead and read the codes, that's the best place to start
Vehicle not starting at all not pickimg up the computer box in fact not commanding the computer box that it recognizes the key. The security light keeps on flashing.
  • Solution
What computer box???
That's probably because the first thing you did was reprogram the key? Why? They don't forget the key
And then did it wrong, so now it doesn't recognise the key.
Plus, whatever "computer box" you've fitted won't be configured to the car
Much, much much more detail needed
But read the codes
So Dave if i buy the whole lockset meaning key,cluster,fusebox and computer box from another ST will it be wise to do so.
Not really, you're just throwing money at it for fun?
Put all the original equiptment back on and read the codes using FORScan, then go from there
You don't know what was wrong with it in the first place
If you substitute all those components there's a very strong chance it still won't work because none of those are at fault.
Find the fault
