Adding a towbar
Hello all,
I'm interested in adding a towbar to my 2010 MK2 Focus Estate. I've seen other models of similar years with towbars so I'm assuming it's possible, my question is how difficult or expensive is it?
Hi There
In my experience its never been overly difficult in Fords. Remove rear bumper, remove the crash bar, towbar goes inside the chassis and aligns with the pre - drilled bolt holes and secure, the towbar then acts as the crash bar, re-fit bumper, (just a rough guide).
In regards to cost its only as expensive as you want it to be, I would have no issues purchasing a second hand setup provided its all there. Same regarding electrics, you can buy plug and play dedicated wiring kits but usually expensive, my mk4 mondeo simply has the wiring spliced into existing car loom with the fitment of a relay on the double filament bulbs to overcome the bulb warning system.
Cheers
