P0016 code
Hi p0016 code coming up on ob2 reader for 1.0 ltr fiesta 15 plate wet belts replaced +pump +tensioner etc .
Did this start immediately after replacing the belts?
Don't know it was done in garage who changed the wet belt.does any one know where came belt sensor is located on engine and if it's easy enough to change ?
Was the fault there before the belts were done? Or did it only start afterwards?
The cam position sensors are right on top of the engine, at the belt end, pointing downwards. There is one for each camshaft. You can swap them over to see if the fault moves to P0017 instead. When swapping them, look inside the loom plugs for any signs of oil, as that can cause bad readings for the ECU.
