Fitting 'ford Power' Start Button In Fiesta Mk7
But our cars do have the glow plug light on the dash and the maual says to wait until it goes out before starting the engine?
Good work Ben!
When it was really cold the last few weks, and my Mk6 was left out of the garage, I did occasionally notice the glow plugs light stay on a couple of seconds.
Oh, and I always start this car up with the clutch down, cos the manual said so. I never did before with my old car (Clio). I thought it was a diesel-feaure? </naiive>
  • Replies 61
  • Views 48.8k
  • Liverpool-S
    Liverpool-S
    Considering this guy has took alot of time to make a picture by picture log of how to do this for any people interested, i find it quite foul that the first few posts SLATED this guy for doing this mo
  • You can still use the key.. i did it purely for aesthetic reasons I thought it would look good and i think it has come out well You could say any modification is pointless.. matter of opinion My op
  • can i explain why i dont think it is pointless, i have the TDCI and as you are probably aware it needs to be kept for a few seconds at ignition before starting for glow plugs, so i turn the key to ign
As for clutch, yeh i put mine down but only through habit my dad has always said it reduces wear on components which would make sense when you think about it, by the way for the power start situation has anyone had any experience putting it where ford do, i just dont fancy drilling a hole into an airbag sensor or something rather bad.
Ant.
where can you get a relay for if you don't mind me asking?
I got it from halfords. £4 I think. 5pin 30amp 12v
Ant.
Well when I removed the stereo, the air vents come out with it. I had a look behind where they put the standard one and there is space behind it and nothing in the way. I was also thinking this. But had already mounted mine where it is
The glow plug light comes on for less than half a second, so the modern diesel/not needing to wait argument is correct. Unless you're one of those tools who turn to ignition pos 3 in one fell swoop.
Seems pointless to me, made more work in the start up process.
Whatever floats your boat, could be worse.... could have been another DRL guide lol
Normally yes - however with the cold weather we had mine was taking up to 5secs to go out. As the manual says to wait ;)
Doesn't make any more work in the start up process.. You can still turn the key to position 3 to start
As said before, i did it for aesthetics reasons
What is it with people on here being so negative
If people have fitted DRLs and done a guide, be grateful for the their help.. Don't just slate them because YOU don't like them
Ben i agree, i will be trying to position it where Ford put it at the weekend il post back here with pictures on how it goes, iv checked on the fiestamk7.com forum and seen your other posts, you deserve gratitude not to be ripped for helping people, I have DRLS and was going to post a wiring diagram but to be honest just didn't see the point really usually this is a friendly place but lately some people seem to be negative about people making mods to their car, even though this is a car modding forum.
From what I can see, when I was checking for footwell blub holders, at the side of the clutch peddle there is a button that is depressed when you press the clutch, ie to start it!
'NoToRiOuS' used the wiring diagram to fit this to his focus
Here's a video .. http://img607.imageshack.us/i/8eq.mp4/
Cheers Ron
Quick question for you, i like the idea of this can you tell and maybe show me some way will this work for a for fiesta mk6 facelift?
Matt
Also where did you get the black/red ford badges are they standard for your model, part numbers?
Hi,Quick question for you, i like the idea of this can you tell and maybe show me some way will this work for a for fiesta mk6 facelift?Matt
For the mk6 facelift
On the Ignition Loom
Stage 2 (Ignition Live) = Yellow/Green
Stage 3 (Starter Motor) = Black/Grey
Please check these with a multimeter before connecting this up
To check stage 2, turn the multimeter to Volts, fix the black prong to a good earth and the red prong to the Yellow/Grey wire, turn the key to stage 2 and see if the multimeter now shows 12v
To check stage 3, again turn the multimeter to Volts and fix the black prong to a good earth, connect the red prong to the Black/Grey wire, turn the key from stage 2 to stage 3 (starting the car) and check the multimeter briefly reads 12v
They are from a website called DMB Graphics.. Search it on google
Cheers Ron
Ey ben,
No problem, you helped me a lot with your diagram even the red led works now :)
TY
Welcome to the Internet. :)
  • 3 months later...
Guide Updated
A much better location for the button! I'm glad you moved it.
I was too scared to cut the dash before lol
Yeah, good luck when stalling! I know! When at a roundabout, and traffic infront moves, and I bring clutch up, but not enough acceleration, and it stalls, whack clutch down, hit button, go!
  • 4 months later...
So when u say will not replace the key, stage one is like audio yeah, and stage 2 is where ur electrics come on, then the last one ignites the car? Instead of turning the key to 3 u just push the button yh??
Imma one click away from buying myself on! :D and I'd defo use this guide :P!!!
Yes, you turn the key to 2 then press the button.
yes the novelty of having a button, but surely key in, pos 1, pos 2 button is slower than key in, 1-2-3 go!
Its like the button on the Honda Civic. Its sort of pointless. (Except on the civic you have to use it you cant turn the key further instead.
I mean why have a system where you put the key to position 2 then have to press a button? I like start buttons theyre a cool novelty but unless you have keyless start like my dad's Megane or the option on the titaniums (now standard I believe?) then its kind of pointless.
Agree with you 100% mate,:)
Its double Jobbing id prefer a 12v Socket for my Sat Nav, Mp3 or Phone Charger,
If i had keyless entry then yes id love a push start but i have an ignition so no thanks.
Keyless start is great, jump in and foot on clutch, push button and go!
