Hello And Maybe You Could Help.
Hello everyone!
I'm a new owner of a very tidy blue 2001 zetec s with 85k miles on the clock.
I only have 1 issue which isn't major but thought I would check if it's a easy fix before sending her off to the garage. On cold starts in the morning it takes a few seconds to start (3-5 seconds) and when sound like a little struggle but when it starts it's fine. Idles fine and revs fine with no misfires. Drives perfect. Start it again if you make a stop and It will start no problem. Only seems to be the 1st time on cold.
Will send it off for a full service soon but want sure if this problem was common?
Thanks for any input everyone and see you on the black stuff.
Do you give the throttle a blip before starting? If so, dont as Fords dont like it when cold. When hot you may have to use the throttle on occasions.
Apart from that a service may be all it needs (including plugs, leads and air filter).
Good luck with the new motor.
Thanks for the reply. I don't pump the fuel before starting but when it's cranking over from cold it helps if you give the peddle a little press to fire it quicker and smoother. Will have give her a big service and a check over.
