Ambient Lighting
Right so I've seen a lot of people posting about not being able to find bulb holders in their footwells or not being able to get bulbs to work. And I've seen others asking where they can get the actual Ford ambient lighting from etc etc
So in my Mk6 zetec (metropolis) I wired in blue footwell neons to the lights [so they would come on when the lights were on]
Yes as you are thinking, it did look awful
Now seeings the theme of my car is Black & Red I wanted to install red footwell lighting as red is pretty subtle and I thought it would look quite smart
I only wanted the lights to come on when the doors were opened
So I wired it to my interior light
This meant that when the doors were opened/the car was unlocked, all the lights I'd installed would fade on and visa versa
Here's how I did it
Equipment Required
LED strips
Black 5 Amp Wire
Red 5 Amp Wire
Soldering iron
Lead free solder
Heatshrink
Heatgun
Double sided tape
Electrical tape
Multimeter
Spade Connections (male & female)
I already had my pillars and roof lining out of the car as these are being worked on at the moment
I bought
Some of this
It can be cut in to 5 cm lengths (3 LEDs)
LED Strip
Some of this
Black Wire
Red Wire
Step 1
Determine which wires to tap in to on the back of the interior light
There are 2 plugs
One plug has just 1 wire going in to it (green/purple) - this is a constant live
The other plug has 2 wires going in to it (yellow/grey & black/yellow)
The yellow/grey is earthed when the doors are open (I believe) [labelled '1' on plug]
The black/yellow is constant earth [labelled '2' on plug]
The 2 wires you want are the green/purple & yellow/grey
Step 2
Solder red wire on to +ve terminal of LED strip
Solder black wire on to -ve terminal of LED strip
(If using the same LED strip as me, solder both wires to one end of the LED strip. Don't worry about the terminals on the other end)
Isolate all connections with heatshrink
Step 3
Cut LED strip to required length
And stick where you want it
Step 4
Feed wires through to near the interior light connector
Step 5
After repeating this as many times as necessary
Connect all red wires to a male spade connector
Within this spade connector also connect a 3-4" piece of red wire
Connect a female spade connector to the other end of the 3-4" piece of red wire
Step 6
Connect all the black wires to a male spade connector
Within this spade connector also connect a 3-4" piece of black wire
Connect a female spade connector to the other end of the 3-4" piece of black wire
Step 7
Cut a 3-4" piece of black wire and connect a male spade connector to one end and a female spade connector to the other end
This will connect to the double plug in to connection 2
Step 8
Connect all 3 female spade connectors to matching connections on interior light
Here are some pictures of how I connected it
I put 1 LED strip in each footwell
1 LED strip in each of the rear cubby holes
And 1 LED strip in the 'secret compartment'
Here are some videos
Hope this helps someone
