Lighting
Hi im new posting so excuse any stupidity but would somebody be able to tell me if the boot light would take a 501 led like THIS , if not what does it take as last night i couldnt see anything i was doin :(
I've worked out through search on this forum what the other lights are, head lamps, footwells etc, so this is the only one i cant find through the search.
EDIT: found out now, sorry for spamming the board
I'm sure you've probably found this out already but the rear plate lights face across the way and not down on the plater.... which is fine when using a regular bulb, but not an led.... even if it is a wide spread one like the one you've posted, the light won't be very good.
I ended up going for something like this.... http://www.autobulbsdirect.co.uk/501-led-extreme-power-1.5w-360-degree-white-blue-red.html
works a treat
Dannyboy
