Rear Bushes
i have a 1.25i zetec fiesta and it has failed on the rear axle bushes. just wondering if anyone has any information on how to remove them? any help would be appreciated.
thanks
kieran
I thought I had a rear bush....... turns out it was a hairy !Removed!
:D
Pain in the !Removed! job but doable.
jack up rear of car put axle stands on chassis.
Support rear beam on a trolley jack.
Remove the big bolts that run through each bush.
Lower rear beam.
This will expose the remains of your bushes.
drill burn hammer scream swear do what ever you can to get the rubber out of the shell so that you can get a hack saw blade through.
Now carefully cut the steel shell.
Resume swearing and hitting with hammer to remove shell.
Grease up axle and pop some polly bushes in.
put it all back together again.
Cup of tea and a slice of cake and bandage the remains of your hands :)
