Two Engine Faults On Year Old Fiesta Diesel
I have just had my first service done on my Titanium 92BHP Diesel Fiesta during which they attended to two faults . The simplest was the oil warning light and chime coming on from cold starts intermittently. The second was an intermittent whining noise ( like a water pump bearing failure noise) from the engine)
The second fault turned out to be connected with the timing belt system, a bearing I guess. They have fitted a timing belt kit which includes belt gears and pulleys and solved that problem. The first problem was a wire connected to the oil pressure sensor( no surprise there) which I hope has been sorted now. It will take me a few days to be sure as the warning was intermittent.
I hope the timing belt fault is not going to happen every year!
Has anyone else had a similar problem?
