Things To Do
Hi I have a mk7 fiesta titanium what little bits have you done to yours inside and out that are nice and easy to change or play with. I seen a post on here about mud flaps and seen the kick plates and iv ordered a set of those. Any input would be nice :)
List is endless mate....
Try searching the forum :)
I'm only doing a few little subtle things to mine; Asian Grill, bulb upgrade (non HID), mist washer jets, spraying wheels a darker grey, de-tango'ing all indicator's, maybe DRL's (Ford ones) and then chip and replacement air filter for the engine.
How easy was it to fit your hids? as i had i fiat 500 before and got a set for them and they would not fit had to buy some aftermarket clip that was crap and did not work!
My first time doing so and was a doddle mate.
Ballasts fixed to underside of headlight unit and all wires cable tied neatly behind the unit.
mist washer jets
Where did you get these from? Easy to fit? :)
Any Ford dealer - straight swap (unless you buy heated ones, will need to wire them in somehow)
Heated: 1708797 - Should be about £5.86 for the pair.
Mine were £6.98 with VAT for the heated pair, worth getting as they're much better than the jet's, 5 minute install too.
see my list of guides Below this post, all of them have been done on my focus but some of them can also be done on the fiesta, including the additional boot light, Ultimate Reverse Bulb and the mist type jets.
Thanks all for the information. I shall be ordering them tomorrow. :)
