Footwell Lights ?
Hi
im after a nice white footwell light in my mk7 so whats my options ?
Any clear white bulbs ?
any links 2 good ones ?
Ive got those in red in my focus and they give out a good spread of light, id recommend them too. B)
Can u get a pic lez ????
anyone got pics of these bulbs above in white in a mk7 ?
As above
and it wont void my warenty ??
As above
Changing bulbs is classed as replacable consumables and should in my opinion make no difference to a warranty.
It doesn't void your warranty when putting air in your tyres or fluid in your washer bottle so don't see how bulbs would affect you unless changing the wiring from standard or splicing in extra cables.
Even if i had to claim i could remove them anyways
Indeed - as i say though - can't see them being a problem, just don't drive with them lit as glare would affect visibility at night unless off road / show use.
Any links to a set of red and white led ones that wont be link spot lamps and a uk seller ?
http://www.ebay.co.uk/itm/2pcs-501-W5W-Wide-Angle-12-LED-Red-Dash-Wedge-Bulbs-/190640440824?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item2c630e45f8#ht_710wt_1185
These are the red ones I have
any pics of them lit up inath ?
Uploaded with ImageShack.us
god there soo bright not 100% sure if i want them that bright .
anything a little less bright ?
Mine: http://www.fordowner...ootwell__st__15 (scroll down for pics of bulb and results)
They are blue but you get a rough idea how much of the footwell is lit up - maybe more-so if you're going for white.
Paul :)
nah edging toward red now to go with the dash lights :)
got a link to the ones you used ?
Heres mine.... White, to match my plastics :D
links ????
just bought the ones in my link :) will see what there like worth a punt a £2.50
there will be no isues with draining the battery with these leds right ?
Nope, being LED they actually use less power than the standard factory fitted bulbs in the Zetec and Titanium models (which are standard 501 sidelight bulbs). They also go off after a few minutes anyway (for example, after opening the door to get in and not starting the engine, or after turning the engine off and not opening a door).
Long as they turn off with the ignition / internal lights you'll be fine.
They don't draw much power anyway.
