Door Speaker Problems
Hey everyone, just wonderin if anybody had any knowledge on removing the door panel on the passenger side as I want to have a look for some loose connections because the speakers are buzzing when music is at low level and when moving any help would be much appreciated cheers
Take the little plastic circle out the inside of the handle you pull to unlock, remove the plastic trim you pull the door with and there's 2/3 screws behind there also. The rest is just held in by poppers so just give it and pull and unhook the top part when lifting up,
Cheers mate very helpful will give it a go 2nyt
