Sony Radio
i have 2012 titanium with the new sony radio my only issue with the car is that the radio loses volume then comes back up ive been told this is because of the dab but it happens when im using the bluetooth is this something that im going to have to get used to or should i take it back?
thanks...
When does the volume drop? I.e. are you driving on the motorway. Does this happen with CD's too?
Just an idea it could be the automatic volume control if it's when driving. May be worth switching off and see if you still have an issue.
ill try a cd see what happens, it happens on both moterways and normal roads.
Yeah if a CD does it then you've either got problems or something set wrong.
You could also have a fiddle with the automatic volume control, the volume could just be rising on the motorway and dropping when you come off. If the car isn't that noisy at high speeds it can be noticeable sometimes.
