Gearbox Problems
I have an S reg Ford Fiesta (1996). When in 2nd and 3rd gears the gearstick has a tendency to drop into neutral whilst slowing down. Does this suggest I need a new gearbox?
Hi
It might not mean you need a new gearbox it could be loose shift rods (Cannot remember correct name) or something has worked loose
How many miles has the car been driven.
Are there any leaks underneath the gearbox area.
There is no drain plug in that gearbox but if oil has leaked at some point then the level will be low.
Are there any untoward noises etc
Does it function well in other gears
Has any other work been carried out recently around the gearbox area
Jamie
Approximately 80,000 miles on the clock. It also starts to slip out of reverse when I am reversing uphill now as well. No sign of any leaks from the car underneath.
sounds like a duff engine or gearbox mount, check these out first
waiting for a more experianced person paid out :-)
