Engine Light
I have an induction kit on my fiesta.. Should this cause the engine light to come on?
Regards
Liam
Regards
Liam
Never seen this happen myself but it is possible, if to much air is getting into the engine then can confuse the cars ECU, check to make sure it is all fitted correctly and there are no air leaks.
Also if the induction kit you've got is a universal one and not a car specific one that could be another reason for to much air getting in.
but TBH more likely it is just a coincidence
thanks for your reply, do you think that the induction kit will make the fuel consumtion worse or better?
It should make it a little worse.it will outvote air to fuel ratio up. More air = more fuel not by much tho I wouldn't worry
