Engine Problem
My petrol S-reg Ford Fiesta's engine has just started to sound like a diesel taxi!!! Any ideas?
What engine is it?
It's a 1242cc petrol engine. Does that help?
I'd get the top end checked.
May be worn valves or the tappets need adjusting.
Cambelt has now gone on the car - think it's terminal this time!!!
£500+ to repair it!
Cheaper to source a cylinder head if you intend to keep it. An S reg won't be worth much but what's it worth to you?
With prices rising all the time I have started using my local motor factor for the spart parts. Much much cheaper. If you went down the 'change the head' route you will need new gaskets etc these places can be a helluva saving. Get jenned up and do as much of your own repairs as you can. I used to do my own a few years ago but with work being so busy i used local garages .....not cheap but useful. Head removal is not difficult but if the valve has damage a piston more trouble but have a look. You will have to fit a new belt and (tensioner on your model ?) and time the engine. This bit is more tricky ...a few years ago we would get cyl 4 tdc with valves rocking and set cyol 1 to firing. you may get the answer to timing here on the forum. good luck. hub nuts???
