Automatic Headlight Sensor
Haz93
Hi guys!
I'm from Slovenia and i like this forum cose it has some usefull information about moding my Ford Focus. I have 2008 1.6 Ti-VCT Ford Focus. It's a sport edition (well not Zetec S model like u have in UK.). My idea is to have a auto lights/wipers, tempomat, mybe xenon next year with arduino self leveling controler. Well that's my wish ;)
To the facts:
First whould like to enable the auto lights in my focus. I bought Auto switch (4M5T-13A024-CA), light/rainj sensor (3S7T-17D547-AB). I have a ELM cable and software so all should be good, but (there is allways but with Ford-s) it's not working.
First a have looked at my auto switch wireing and i think there are all wires that i need. Picture:
IMG 20131117 125711
Then i looked at the connector for sensor in the top of the interior light. There was only one red connector and one black. So i have made a wire to the C98 connector in the PJB. Now the tricky part. The C98 connecor does not have pins so i have opend the PJB and found this:
IMG 20131118 135436
IMG 20131118 135445
Oky..as i found somewhere here it must be connected pin 4,11 and 12. So i have made the connection to the sensor connector:
PJB pins
Then connected the sensor to pins:
Sensor connection
So what am i doing wrong?
I have enabled it in ELMConfig but still not working. Eny ideas guys?
Have a read of this buddy. I have completed this mod and it has been heavily covered. I think that you are using thrme wrong wires. In this thread I include pictures of the correct connectors going into the sensors n mirror
Read from the start
Hey!
Tnx for info. but i have checked all the wiering from sensor to PJB C98 pin 4,11,12. I have 12V on pin1 and ground in pin2 of rain sensor. I checkd that i have connection from C320 pin no. 4 to connector in PJB C103 pin 5.
As i can see from here i think it must be a autolamp relay in my version of PJB that is PJB 7M5T-14A073-BB.
There is only one issue that i'm not sure. That is in the Entire shematics PDF file i found a relay R21 Autolamp relay and it's fitted in PCB. Does this relay must be fited too?
My version of PJB is:
PJB 7M5T-14A073-BB
PJB 7M5T-14A073-BB
  • 2 years later...
On 26/09/2012 at 11:07 PM, Brigante said:
Things like this make me glad I got a ghia ;)
Things like this make me glad a bought an Edge :smile:
This weeks biggest bump award goes to Chris with a 2 year, 8 month and 30 days Bump!
:whistling:
  • Like 3
:whistling:
Along side the "most pointless reply on a very old thread award".
  • 7 years later...
On 9/26/2012 at 10:16 PM, Haz93 said:
You will need a light and rain sensor like this one :
http://www.ebay.co.uk/itm/Ford-Fiesta-MK5-Rain-Sensor-2002-2008-3S7T-17D547-AB-/180846468028?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item2a1b4a1bbc
http://i.ebayimg.com/t/Ford-Fiesta-MK5-Rain-Sensor-2002-2008-3S7T-17D547-AB-/00/s/MTQ5OVgxNjAw/$(KGrHqV,!rYE88g6(LOVBP,GtPMvt!~~60_12.JPG
Also the auto dimming rear view mirror too if you want to be able to hide all the wiring
http://www.ebay.co.uk/itm/FORD-MONDEO-ST220-MK3-2003-2007-auto-dimming-rear-view-mirror-/110947152478?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item19d4f7325e
http://i.ebayimg.com/t/FORD-MONDEO-ST220-MK3-2003-2007-auto-dimming-rear-view-mirror-/00/s/MTIwMFgxNjAw/$(KGrHqF,!ncE-)u!kK6oBPz107qnPQ~~60_12.JPG
Doesn't matter if its from a Focus 05-11 or Mondeo 04 - 11 maybe a Fiesta too.
As you can see the mirror mounting is different to the standard mirror. I got around this by unscrewing the metal plate in the auto dimming mirror mount and filing a grove in the two side prongs you can see in the picture. this will then allow the mirror to slide onto the standard mounting.
You will also need to be able to edit the GEM module, using the Guide by Preee and the ELM cable. Or pay a ford garage to do it (£75 an hour) average.
And lastly if you want the Auto lights to work you will need the auto light switch
http://www.ebay.co.uk/itm/2004-2010-FORD-FOCUS-MK3-MK4-LIGHT-SWITCH-AUTO-/280733537630?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item415d05d55e
http://i.ebayimg.com/t/2004-2010-FORD-FOCUS-MK3-MK4-LIGHT-SWITCH-AUTO-/00/s/MTQ2OFgxNjAw/$(KGrHqR,!iQE5fk!2tM2BOYKHCBY4!~~60_12.JPG
I will do a guide when I get the time.
Where will I get the edit for gem as I have everything else just need to know where get the edit thanks
