Earth In Centre Console Area?
I currently have a positive feed running down the centre console coming from a piggyback fuse adapter in the glove box fuse box. I am looking for an earth to connected some LED's to. Where is the easiest place to find one?
Any help appreciated.
Cheers, Olly.
Anywhere there is a metal screw or bolt into the metal body will act as an earth.
Yep take a look at your battery and you will see the negative only goes to the chassis.
Cheers guys, will take a look later on. Do you think this is simple enough, or would it be easier to just connect the rear footwell LED's to the courtesy footwell lighting from the front?
I wired my rear courtesy through the centre console off the front passenger footwell. Easy enough job. Just splice into the wire behind the glove box.
Yeh, might do that for now, as its an easier job, then if i want to have it on constant, ill do it later on.
Cheers for the help, Olly.
