Visteon 6000Cd "phone" Issue
My car is fitted withe the Visteon 6000CD but as far as I know not Bluetooth (no signs of Voice on the stalk).
Unfortunately the radio/CD playback (probably Aux too if I used it) keeps being interrupted & the display shows "PHONE". This is happening enough to be a complete pain. Often the only way to restore sound is to switch it off & then on again.
Anybody else had this?
Could it be a firmware problem & if so how can I check version & update?
Any other suggestions?
bump.
Am I just the "lucky" one? :cry:
I'd pull the radio forward and check that all wires and plugs in the back of the quadlock connector are secure.
Be sure you have your radio code before doing so!
A wire moving around is a likely cause of the random phone situation, although I have searched for this error and it has been recommended to put a resistor into the system to stop an apparent problem where random power feedback can give a false phone connection signal to the radio
From AVForums.com-
Problem should be solved by short-wiring pin 5/6 but nevertheless I have connected 500 ohm between pin5 and 6 on B second connector just to be ensure that low current flows (12/500 = 12 mA) if by any chance phone-mode wire connects to ground. For better appearance i soldered 500 ohm SMD resistor inside the radio on radio's motherboard.
Thanks for the reply.
It seems to have stopped for the moment so it could well be a poor connection that is being jiggled about.
  • 8 months later...
I've connected ping 5 and 6 with 500 ohm resistor. Radio still showing "phone" on screen. Maybe i've connected wrong pins. Pins connected in my radio are "Phone Mode" and ".+5V". Is that ok?
My radio:
