2.5 Estate:- Water Drain, Door Trim, Valve Clearances
I have a 2.5 estate (swept back headlamps model) and ask for advice
1) I need to remove the nearside rear door trim to fix the lock (it's very noisey when locking), not too sure what tools, nor where clips and/or screws are etc; has anybody got any pictures or done the job themselves.
2) The rear bumper has 3 water drain slots, the one on the nearside is only pin hole wide and gets blocked very quickly, whilst the other 2 are decent slots, is this difference in slots normal or is it a manufacturing defect; and what will be damaged if I drill the slot out a bit bigger.
3) The engine is the Zetec 1.6 16v jobby, 100PS and it seems as though the valve clearances need doing, if so how often and is it easy.
Many thanks
