Bolt Size
I am about to change the rear hub assembly on my 1.6 Ghia Mk2.
I believe the securing bolts are external torx, but I do not know what size, also does anyone have any tips to get access to the bolts.
If i understand what you're after properly it's HB1 bolts you need, Finis code 1471995 (M12 x 65mm).
Best to check with Ford thst they're the exact ones you are after though.
Best access is from below.
hi Stoney 871, thanks for the reply. I think that they are HS1- do you know what size they are?
