Rca Converter, Use Front Or Rear Speaker Output
Im installing a Infinity Basslink, wich handles highlevel speaker input.
I have located the 4 speaker pairs behind the headunit.
I dont have rear speakers, so the output to the rear will be not be feeding speakers. If i use the front output, the same signal will be feeding speakers aswell.
So far it seems that using the rear is the best. BUT, when i connected a small 4,5" speaker i had to the rear output, it was a much higher tone (more treble) than the sound i got when i connected it to the front outputs.
Does the headunit not supply full range signal to both rear and front?
In my case i dont need a full range, but only the low end (bellow 100hz).
