Zetec S Ecoboost 125 Drl
Has anybody got any pictures of there car with them on at night ? eager to see them seen as my car is 8 weeks away from delivery :(
They look like the one in your profile pic mate. The ZS don't have LED DRLs...
I see I see, what bulb are they then ? :s more than one ?
Just one bulb on each side for DRL or ? If thats the case then there's 2 h15's on each side ? (Full beam and DRL)
The DRL is built into the main/high beam bulb, so you have your indicator bulb, sidelight, dipped beam and main beam in the light unit. So it's 1 H15 bulb at either side, 2 for the whole car.
Ahhh okay I see I see makes sense now then, that's definately an unusual one. Thanks for your help
They're found in VW's, Audi's and Dacia's I believe, not sure where else, but quite a few manufacturers are using them now.
Hopefully they start to produce some aftermarket versions of the bulb type then soon
Do the titanium LEDs turn off at night or dim? Are they used as side lights?
Hi, the drl's dim when you turn on the switch to sidelights/headlights..
