Removing Dashboard Screen?
Hi there,
I have dried drip/water marks on the inside of the clear plastic bit on the dashboard infront of the speedo
anyone got any idea on how to remove it so I can wipe the inside?
I'm pretty sure you can't remove the plastic front. The clock modules are normally sealed units
Oh great :( how an earth did it get in there is my question though
I believe you can as Lockwood sell new bits to go behind the needles for speed, revs, fuel etc.
You should be able to open the casing but watch out for the fragile plastic clips.
Also remember that a new cluster is expensive and a real ball ache as it is part of the PATS system too.
I think I might just leave it then.
