Using Fords Ids-Vcm To Check Fuel Pressure ???
hi all how do u use fords ids-vcm to check fuel pressure and what ever else needs checking on a 2005 focus st-3 ??, I've got a focus st with mil light on and to fault codes p0087 and p2178, a local garage has ford diagnostics kit, but he used to using a snap-on kit, its there a uses guide for using ids-vcm ? Or do any1 know how to check or what to check for low fuel pressure using fords diagnostics kit on my st ?? Thanks all
Ive got ids. Basically you go to live data and select fuel parts and cylinders to check pressures
Ive got ids. Basically you go to live data and select fuel parts and cylinders to check pressures[/quote
Hi m8 thanks for reply, nice1 your a star.
