New Engine Oil?
Bit of a bump on this.
Curious to confirm if the Ford - Castrol Magnatec Professional E 5W-20 is purely for the 1.0L Ecoboost and Ford - Castrol Magnatec Professional A5 5W-30 for the 1.6L Ecoboost in the ST?
http://ford.castrol.co.uk/ford-castrol-magnatec-professional-E-5W-20.html
http://ford.castrol.co.uk/ford-castrol-magantec-professional-a5-5w30.html
5W20 is the thinner oil when the engine is at 100°C as designated by the 20, 30 will be thicker at 100°C.
So 5W20 is the thinner oil and therefore the more fuel efficient oil as it has less drag on the engine.
Hmm, did a search under Google Shopping for 'ford oil top up kit' and the 11th item down is slightly off topic :D
5w20 1.0 ecoboost only. Its been developed for that engine only, no other oil is recomended, the ecoboost engine uses a variable pressure oil pump using a solenoid controlled by the ecu.
Hence my earlier question regarding the 1.6L EcoBoost engine in the current ST's.
For anybody looking to get the 5w20 oil, they can get 4L for £39.50 here:
http://www.amazon.co.uk/CASTROL-MAGNATEC-PROFESSIONAL-5W-20-Engine/dp/B00A6S8DPK/ref=cm_cr_pr_product_top?ie=UTF8
Allen ford sell alot of there ford parts and accesories , and oil via amazon and ebay now. Ref your amazon link
Aren't they the dealership with some poor history on ebay selling?
No idea, I didnt realise who auto accesorize was until I bought something off them on ebay.
Well, good or bad, there eBay store has the same 5W-20 oil for £38.69 so slightly cheaper than through Amazon:
http://www.ebay.co.uk/itm/New-CASTROL-MAGNATEC-PROFESSIONAL-5W-20-Engine-Oil-5-Litre-FORD-ECOBOOST-ENGINES-/121019385326?pt=LH_DefaultDomain_3&hash=item1c2d5145ee
Listing states 5W-20 5L but product description shows an image for 4L. There is an additional error under 'Item Specifics' where they state the 'SAE Viscosity' is 5W30. Sloppy errors :(
Funny how it sells for ecoboost 1.0 only, in 4 litre pack but engine takes nearly 4.5. Lol
HAHAHAHAHA just a little
  • 1 year later...
Finished at 5pm.
Need a fuel hose and the standard recirc valve to arrive then its off to ford for the PCM update
Replacement engine after your loss of compression I read about on another thread?
http://www.driverstechnology.co.uk/oils.htm
this explains oil grades. I found it using google. I do not guarantee it to be correct
