High Level Brake Fuse
Hi would anyone on here be able to point me to the correct fuse for the high level brake light please. For a fiesta mk6 pre facelift
Thanks in advance.
It's probably not a fuse if the other 2 work as I would imaging they are on the same fuse so either it has a bad earth or its blown
Thanks for your reply, would you happen to know how to remove the light unit so I can check, I removed the two rubber grommets from inside the tailgate, but could not see any clips or anything to release the unit,
Any tips/help greatfully received :-)
After a quick google this should be right for your car. The bit you need is the last post on the page
http://forums.overclockers.co.uk/showthread.php?p=17680929
